BMW E38 E39 ZF 5HP24 transmission for MY1997 XK8
Old 02-02-2016, 10:42 AM
Pristine97XK8Convertible's Avatar
Default BMW E38 E39 ZF 5HP24 transmission for MY1997 XK8
1st gear on my gearbox has gone.
I'm trying to source for a ZF 5HP24 replacement.
I note that the early series BMW E38 and E39 also used the same box.
My question is do they come in the same housing as the MY1997 Jaguar XK8 and would fit perfectly? Bimmers are certainly much more plentiful around than Jag XK8/XJ8's.
I'm still driving it around, manually shifting and lots of fun...
Thanks a lot in advance.
Old 05-22-2018, 08:24 AM
Dsucharda17's Avatar
Did you ever do this swap I'm in the same boat rn
Old 05-23-2018, 11:48 AM
I found a transmission specialty shop which did a complete overhaul of my ZF 5HP24 for a very reasonable price which is less than the equivalent of US$2,000 and carries a 6-month or 5,000km warranty. The main culprit was the doomed-to-fail-in-time split A-drum.
I still have no idea if a box from a BMW E38 or E39 could be simply swapped in.
Old 05-23-2018, 12:20 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
No. The bolt pattern, mount are different, and I think the ratios, speed sensors will not conform to the TCU.
Old 05-23-2018, 08:20 PM
Gus's Avatar
Gus
Gus is offline
Received 2,212 Likes on 1,702 Posts
I would first check the shifter linkage adjustment to be sure it is correct.
Gus
www.jagrepair.com
magmedia
01-31-2016 04:38 PM
o1xjr
01-28-2016 08:29 AM
JaguarXKR
01-23-2016 01:31 PM
JagGirl1954
XE ( X760 )
01-12-2016 09:18 PM
Tirefriar
XE ( X760 )
01-12-2016 09:05 AM
Quick Reply: BMW E38 E39 ZF 5HP24 transmission for MY1997 XK8
