Bolt Size for Engine lifting/removal Points 4.0L
Hi,
Could anyone tell me the size of the threaded bolt holes at the firewall/back side of the cylinder heads on a 4.0L XKR engine '96 - '01?
Those are the holes used for attaching the lifting eyes for engine removal.
They appear to be 14mm, but I cannot tell the thread pitch.
Thank you.
Charlie
Thank you.
Charlie
CharliePar (04-09-2014)
Thanks for your ideas. I have been able to determine the bolt size after some trial and error.
For future reference, they are 14mm x 1.5mm pitch. Length of the bolts can be up to about 30mm.
I am planning to use chains between the bolts and then attach those to the tilting device on the engine hoist.
philwarner
09-05-2015 10:05 AM
