bonnet earth lead
Johnken (11-12-2017)
Ground Lead Bonnet Part# LMB3741AA Over $54.00
Try an auto parts store to find a knock off replacement for $5.00. Make sure it's a flexible thick gauge braided wire with connectors if possible. Bonnet struts must be taken off to get at left frame 13mm nut holding on the ground lead, same for the bolt connection to the bonnet, it's an easy install with the bonnet struts disconnected and the bonnet leaning forward and braced with a 36 inch board so not to fall back on you while your working, clean all connection surfaces and bolts with wire brush before reconnecting new ground lead.
Received 6,315 Likes
jaguar51 (11-14-2017)
vacolorito
09-25-2015 09:29 AM
