Boot (trunk) lights
The boot lights aare control by a micro switch in the locking mechanism. Do and advanced search for boot light and you will find some good write ups on dis-assembly and repair of the switch.
In most case after you open it up a good cleaning is all it needs. If you remove the trim around the latch I think the switch is mounted to the lock mechanism side.
Mike76 (11-25-2015)
Winston Gilbert
02-11-2016 02:32 PM
