Bounce idea off you? Temp fix noisy control arm bushes - RESOLVED
Recently I've been getting loud squeak noises when suspension height shifts or turning in parking lot. All looks tight and ok front suspension. If I hadn't heard this before I'd be quite concerned.
Last time I replaced upper control arm bushes with proflex. Fixed problem. I'm submitting a warranty replacement request with them. But that's going to take a few weeks even if approved.
Got to thinking about this and had an idea. It would be easy enough to pull the upper control arm components (bolt, washers, spacers, metal cylinder inside bushes, bushes), grease the heck out of each, put them back.
On the small chance someone has done this, or in case I'm missing something with this idea I wanted to bounce this off you. Bad idea ( destructive or waste of time)? Unlikely to help? Possibly could work?
Thanks guys,
John
Thanks guys,
John
Last edited by GGG; 07-05-2019 at 02:41 AM. Reason: Add "RESOLVED" to thread title
Thanks Graham. Steve, it's just noisy. We will see about warranty. I went in there today to fix bad headlight. Wow once you figure it out removing the wheel well inner lining is really easy! Anyway while jacking her up I looked and listened carefully. This may be the sway bar bushes themselves. Guess they are about 50k miles old.
I'll let you know how it goes and what I find.
Thank you both,
John
Thank you both,
John
If you go back in there, use silicone grease.
I've used it on poly bushings and had no issue with them.
Using the graphite filled ones on the Spit6 I'm building now, so the jury is still out on that one. Had to turn them down as they don't have many request for 50 year old Triumph bushing. LOL
JagsteRJX
12-31-2016 12:07 PM
w1ldcard
07-31-2014 09:56 PM
