Brake, ABS, Check engine lights...help
So I started the XK tonight and the lights did not all go off as usual after ignition. The Brake and ABS warning lights stayed on. I shut it off and restarted. This time the same deal, except now with the check engine light joining the party. Also I notice the ASC button in the console was on, and I couldn't switch it off.
The manual says brake fluid could be low, but I checked and that isn't the case.
Any help would be greatly appreciated.
