Brake Bleeding after ABS module repair question
Attempted the cut your ABS Module in half and resolder the power connector fix yesterday to try to resolve the ABS/Traction light issue. Interesting procedure, though truthfully did not see any breaks, though these old eyes are definitely not the best for small close in work. Soldering all went well though and RTV should finish curing in a few hours.
My question is - after re-assembly, I am going to have to bleed the brakes - bought a big bottle of DOT4 since I would like to renew the fluid anyway - but, can I use one of those one man DIY brake bleeders that suck the fluid out through the caliper? I have one and use it all the time on the motorcycles with pretty good success, but I do not know if there is any issue with the ABS system and sucking the fluid out vs. pushing it out with the normal two man brake pedal pump system. Did figure out after reading other posts that the rotation is counter intuitive (start at LF and work your way out to RR) but I will do that. Didnt see anything about the pull vs. push though.
Thanks,
Mark
Thanks,
Mark
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
KarimPA
09-12-2015 08:15 AM
