Brake Booster Vacuum Pipe XK8
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Just found a broken pipe that runs from the Brake Booster (Servo) to the throttle body induction elbow. The broken plastic pipe-end is still in the elbow, sticking out about 2cm. Anyone know how to remove this and where to obtain a new vacuum pipe for a XK8 1997.
If so, it's the Brake Vacuum Pipe - P/N MJA5910AC
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Resolved the broken pipe issue by having a new connector machined to fit the throttle body elbow. Then going to use a standard 9mm flexible pipe to connect back to the original broken vacuum pipe that runs back to the brake booster (servo) thank you for the booster diagram
clubairth1
29
05-10-2024 12:57 PM
xjrjag
09-27-2015 01:53 AM
