Brake Fluid Low
The fluid reservoir has a fluid-level indicator switch which normally operates when the fluid level is low, illuminating the brake fluid level warning-lamp.
![Brake Fluid Low-brake.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/143545d1488583504t-brake-fluid-low-brake.jpg)
If the sensor is faulty it will either fail ON permanently or OFF permanently. Less likely is a break in the harness but the connector could be loose.
Rogerj (03-03-2017)
