brake lights inop but third brake light works - RESOLVED
Hello,
I have a 2000 xkr coupe and driving to work I was told my main brake lights are out and the third light is the only one that works. I confirmed this. I did a search on this site and it looks like it may be the brake switch, but is the third light affected by this? I just want to fix the problem accuratley. I did not have a rear brake warning failure. I've had other rear light grounding issues in the past, but that has been corrected. Also, I tried look at the wiring diagrams but the work computers block the weblinks. I'm using my phone to post this message.
I appreciate the help! This is my daily driver and New Jersey will pull you over if you have a light that thinks it wants to go out.
2000 xkr coupe 122k miles
jimangle (08-12-2014)
I also remember reading some threads on tail light grounds, do a search on it and you will find many members had to 'improve' the grounding in this area, I'm not sure if it would affect just brakes or all lights or a mix ? Let us know what you find.
oops, reading too early I see u've visited the grounding issue, maybe just double check anyway
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
