Brake noise, looking for replacements 99 XK8
I've had an intermittent/rotating metal sounding noise out of the left front wheel. Maybe a brake pad dragging on the rotor, sticking caliper....just not sure. The front rotors are worn pretty good, but still have decent stopping power.
I was thinking of getting 4 new rotors, and some EBC pads, since I don't know when the last owner serviced the brakes. I've read a lot of discussion here about the slotted/drilled rotors, which I really don't need.
So, any good sources for the stock/plain rotors? I could have a local mechanic here install them. Never did brakes before...
I priced on autopartswarehouse 4 EBC plain rotors around $290, plus EBC redstuff pads around $190-front&rear. Is this any good?
Thanks!
Thanks!
I got replacement rotors for my XJ from R1 Concepts. They have been perfect so far. I just got the plain ones as I do not do any racing in the car.
http://www.r1concepts.com
I put brembo rotors on my front, probably just as good as the EBCs. Consider the Akebono Euro ceramics Dave, I had EBC reds and the dusting was considerably bad. Less than factory pad, but still...the akebonos are much less.
Here's a link to everything you may need from Tire Rack. (no rear rotors, sorry) I bet the caliper guide pins just need some good lube, don't neglect that part.
If you want to do this real quick, its a matter of removing the wheel then those pins. The lube is called caliper grease, synthetic...found at any store.
I can get you the torx size if you like, no need to start the project w/o making sure you have the correct tools for the job.
I thought of the wheel bearings also, but with the low miles (50k approx) I'd predict they would last a little longer, but they can be an issue. Worth a little inspection time I agree.
If the brakes are original, and if the first owner let it sit for long periods (dave is the 2nd owner it appears, that isn't much driving since 99), that's why I am guessing sticking brake calipers.
I watch Wheeler Dealers quite a bit, and whenever cars sit around, the brake pistons gunk up, sometimes corrode. I'd take the pads off while lubricating the pins, and check to make sure nothing is holding back the piston either.
Thanks oldmots, I'll check that out too! I had her out today for a short drive, and sure enough get the grinding noise. Now this seems to occur soon after I've applied the brakes. Sometimes I can get it to go away by braking again.
I noticed it the first time about 3 weeks after I got the car when braking. Something is sticking. I'm going out of town (no not taking the Jag it will be garaged) so it will be next month until I can look at this.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
Sshenton1975
08-30-2015 09:29 AM
