Brake pads
Received 1,684 Likes
I don’t let them get less than 5 mm. Which is about 0.2 inch
By the way, the ebc redstuff pads I use on multiple vehicles are a night and day improvement over the OEM pads. I recommend them to anyone wanting an upgrade in stopping power over their current set-up.
They will stop the car quicker than the OEM pads, leave very little brake dust, and are very easy on the rotors. Which was a surprise for me considering their increased friction coefficient.
Z
Z
Z
Z
Jack
compound is the one I prefer for my driving needs. Which are “spirited, but far from racing”.
Amazon has them, as well as vendors like Summitt.
the front pads for my 2002 XKR are this ebc part number:
Front: EBC Brakes DP3689/2C Redstuff Ceramic Low Dust Brake Pad
Rears: EBC Brakes DP31198C Redstuff Ceramic Low Dust Brake Pad
i have the standard ATE brakes, not the Brembo’s.
Amazon:
https://a.co/d/74y0vHN
Z
Z
This new setup pretty much made me forget wanting to add an electronic vacuum pump to the system.
I’m on my 2nd set of ebc redstuff pads in front. The rotors were put on with the first set, and still measure the same as new. And no grooving or hot spots either. I was sure I’d wear out the rotors as the same rate as the pads. Nicely surprised with the longevity of both pads and rotors.
my first set of pads lasted 58,000 miles. I change them when the material thickness is down to about 5 or 6 mm.
Z
Z
Sonspit
07-11-2014 08:52 AM
