brake upgrade
You will have to tap the upright caliper mounting holes to 14mm, they are normally a fine thread (1.5mm pitch) but I always do it standard 2mm so I can use caphead bolts. The brake disc back plate will need to be removed/replaced, I think you can flatten them out like you would do for the rear, I normally discard them.
The brake flexi will have to be changed, again normally they are a goodridge stainless braided item.... Thats it and away you go
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
wvanepps
10-04-2015 10:01 AM
Pluckie
10-03-2015 07:57 AM
