Break light on.
JagV8 (09-12-2017)
if the brake light is on and its due to the handbrake, then you will get the handbrake warning if you try to move the car. I made the mistake of thinking an issue I had was the handbrake, but it was a throwback from an ABS issue (front left sensor). Once that was replaced, after 3 runs , it cleared itself. Torquepro will read the codes and tell you what it is.
