Broke off thermostat housing port to expansion tank bleeder hose...
Old 11-22-2012, 02:09 PM
hawaiianjag's Avatar
Default Broke off thermostat housing port to expansion tank bleeder hose...
I managed to break off the little knob port on the thermostat housing where the bleeder hose from the expansion tank connects to.
I was thinking maybe some high temp. RTV red silicon would work to fix this?
or do you recommend I replace the entire thermostat housing as a result of this stupid mistake I made while trying to get the temporary hose off to install the new bleeder hose I just got.
Thanks for the advice to come
Old 11-22-2012, 02:46 PM
GGG is offline
Received 16,864 Likes on 12,186 Posts
If your temporary fix to re-attach the outlet pipe goes wrong you lose coolant fast with all the associated overheating risks. Go for a replacement ThermoStat Housing and make it an aftermarket aluminium one.
The OE Jaguar Thermostat Housing is a regular failure and the aluminium version is a once-and-for-all fix.
The following 2 users liked this post by GGG:
Bob OB (03-28-2013), hawaiianjag (11-22-2012)
Old 11-22-2012, 03:03 PM
thanks graham. I figured so. It broke off pretty easy so the plastic must be pretty brittle and ready for a replacement anyway. Knowing my lack of mechanical skills should I have a pro do the replacement for me or is it not very hard to install a new housing? Also while i'm in there should the thermostat be replaced as well in your opinion? My xk8 has 61k on it at the moment
Thanks again for all the help
Old 11-22-2012, 03:36 PM
RJ237's Avatar
Received 2,815 Likes on 2,244 Posts
It's not very easy getting the rear bolts back in and tight. Removal is simple, just break the old housing into pieces. If you do a search you will find info on using a crowfoot wrench. If you don't mind the expense, life is more enjoyable if someone else does it.
Definitely replace the thermostat, they have been known to stick in the closed position when they fail, a serious risk for the engine.
Old 11-22-2012, 03:48 PM
I think it's time I tackle a job myself and since I just bought a new 200 piece tool set im going to attempt to do this myself. It doesn't seem that hard besides the hard to get at nuts, etc. It might take me 3-5x times longer than a pro I think its worth a shot.
Since I will be replacing the thermostat and the housing and I can only find write ups for the housing alone and the thermostat alone is there anything I should do or not do that you can think of when replacing both thermostat, housing, and hoses? Once I take off the housing is it simple to just pop in the thermostat or is it more involved and some people advocate removing the bleeder pin from the t-stat? Do you guys recommend this? Ill be doing as much research as possible but if anyone has done this before themselves any advice is much appreciated.
I like to work on cars but I just don't do it much and this looks like a good opportunity for me to gain some experience and hopefully all goes smoothly and I don't break more parts
Old 11-22-2012, 05:26 PM
GGG is offline
Don't spill coolant over the Serpentine Belt or it will start to squeal on startup. Maybe I'm oversensitive but that sound drives me mad!
If you decide to break the housing to remove it, make sure no pieces drop into the cylinder block. The last thing you need is a piece of plastic getting into the Water Pump impeller or partially blocking a waterway.
The Thermostat fits into a groove in the Thermostat Housing. it takes no effort to fit it and the rubber seal on the perimeter will hold it in place until you fit the cover:
Broke off thermostat housing port to expansion tank bleeder hose...-16-thermostat-fitted.jpg
I don't have any worries about either leaving the pin in or removing it. Never remove them myself. Just be sure to place the hole at the top like in the pic.
Which hoses are you planning on changing at the same time?
hawaiianjag (11-23-2012)
Old 11-22-2012, 07:25 PM
RJ237's Avatar
Take a close look at that connecting pipe that goes across the top. It's made of the same plastic as the thermostat housing and can be brittle. I probably should have replaced mine but didn't. Maybe next year.
Old 11-22-2012, 07:41 PM
berlin1977's Avatar
Graham you may what to send him the pic showing the radiator drain plug and location it made my life easier. With the miles on the car, which were the same as mine I would change the upper , lower radiator hose and the shot hose. Part of my problem was the upper hose was starting to get soft and enlarged on the ends. For a few bucks more and piece of mind it's worth it. Jim
The following 2 users liked this post by berlin1977:
GGG (11-23-2012), hawaiianjag (11-23-2012)
Old 11-22-2012, 09:50 PM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
If you are not using a crowfoot wrench, pick up a spare wrench of the correct size that you will be bending to reach that one bolt. That way, you don't end up breaking up your new tool set.
hawaiianjag (11-24-2012)
Old 11-23-2012, 01:04 AM
very good tips everyone! I was planning to replace all the major hoses & clamps I can see that I will be taking off in the process of replacing the housing and t-stat since they probably have never been changed since the mileage just hit 60k.
So just to be clear, I should be draining all the coolant from radiator then take apart hoses, remove hosing then fit new housing and t-stat, then reverse process of removal, lastly fill up with dexcool orange coolant(50/50 coolant and water???) then warm up engine by running at 3000 rpm w/ heater on full blast to get any air pockets to pull through t-stat... thats basically what I got from the research ive been doing from various sources so far.
All the help is much appreciated everyone. If anyone thinks of anything else please let me know.
MAHALOOOOO
Old 11-23-2012, 02:48 AM
GGG is offline
Originally Posted by berlin1977
Graham you may what to send him the pic showing the radiator drain plug and location it made my life easier. ................ Jim
Jim,
Good idea - it's not exactly easy to find!
A plastic plug (item 1) in a plastic radiator - extreme force is NOT required.
Attached Thumbnails Broke off thermostat housing port to expansion tank bleeder hose...-xk8-radiator.jpg   Broke off thermostat housing port to expansion tank bleeder hose...-xk8-radiator-drain-plug.jpg
Old 11-23-2012, 02:57 AM
GGG is offline
This Parts Manual diagram may help as a reminder of where everything goes:
JAGUAR XK8 - Thermostat & Water Outlet Pipe.pdf
Rubber Seals items 5, 7 and 10.
A new Thermostat includes Item 5 and Item 7 is included with a replacement Thermostat Housing. The two Water Outlet seals are almost always re-useable.
Old 11-23-2012, 05:32 PM
very very helpful diagrams Graham. You just helped me big time. Looking forward to having the cat purring again.
Would be broke from labor costs before long if it weren't for this great forum that has helpful experts like yourself. It is about time I become a paying member on this site for all the help with the 3 Jags ive owned over the years.
GGG (11-23-2012)
Old 11-23-2012, 05:53 PM
GGG is offline
Originally Posted by hawaiianjag
............... It is about time I become a paying member on this site for all the help with the 3 Jags ive owned over the years.
No charge for membership - all supported by sponsors and advertising.
Many enthusiastic members here give their time and knowledge but those who ask the questions are just as important as those who answer them.
Together we all keep some of the most beautiful cars ever built roadworthy and enjoyable for ourselves and their future owners.
Old 11-23-2012, 05:57 PM
Received 6,330 Likes on 5,516 Posts
Not so fast Graham, I was just going to PM my address for the cheque to be sent to.
There would have been a beer in it for you.
Old 11-23-2012, 06:32 PM
GGG is offline
A beer from a Scotsman! Pinch me, I must be dreaming.
Old 11-23-2012, 06:49 PM
berlin1977's Avatar
Hey you forgot the Scots, Irish, Slovak. After all we are a melting pot in the US. Any beer other than a light would be great.
Old 11-23-2012, 10:52 PM
If I'm in a restaurant and asking what beers they have, I usually tell them not to mention the ones with light in the name.
Old 11-24-2012, 05:00 AM
steveinfrance's Avatar
Lot to be said for Lager Free Alcohol.
Old 11-24-2012, 08:01 AM
Received 1,425 Likes on 1,067 Posts
Correct size wrench for those thermostat housing bolts is: 8mm - Hawaiianjag - check my profile and postings - I completed this job in my 00 S Type... this may be of assistance.
Quick Reply: Broke off thermostat housing port to expansion tank bleeder hose...
