Broke off thermostat housing port to expansion tank bleeder hose...
hawaiianjag (11-24-2012)
For some reason I though there was an option to be a paying member on this site. I must be thinking of some other forum.
The parts arrive on Monday(fingers crossed) still haven't located a 8mm or 5/16 crowsfoot on this island so I might elect to break the thermostat housing carefully to not loose any pieces that might come back to haunt me later once shes buttoned up.
To anyone that has smashed the plastic housing to get to the back bolts easier....is there a specific place I should be placing the chisel before I bang it with a hammer to avoid pieces flying everywhere I dont want them?
Glad to know I wasn't the only one to break off that outlet port Chopr. I have not been able to drive the cat for days and it is starting to mess with my chi.
I used this wrench w/o having to break the old thermostat housing apart - remember, breaking the housing apart will help you get the bolts off but you have to get them tightened....
Good point. I do have to get them tightened afterwards! How could I forget. haha I wanted to get this job done asap and amazon shipping next day air for that wrench is $36!!! The slower shipping options would take 2 weeks to get me that wrench. The price you pay to live in hawaii!
Thanks abonano
Thanks abonano
If you have or can borrow an angle grinder or other cutoff wheel you can open a box end, but you still have to bend it, which requires a lot of heat, like oxy- acetylene.
What I did was use socket head screws and tighten with a ball end socket wrench, a little easier to find. Looks like allen head wrench only ball shaped. It's still not easy.
As far as breaking off old housing goes, stuff a rag in after removing thermostat and break top off using cold chisel and hammer, then push rag down and chip away. The pieces will not get past the rag.
hawaiianjag (11-25-2012)
Another thought I have read on the forum... once you get the bolts off - use 2 of the 3 bolts from the housing cap that bolts the thermostat in place - they are the same size, just shorter - use those for the 2 back bolts in the thermostat housing base - also, take a grinder and cut a slot into the 4 bolts and tighten them up with a large flat blade screwdriver
#28
It's important to make sure the Cylinder Block area where the Thermostat Housing sits (arrowed in red) is clean before fitting the replacement. Remember it's aluminium so use something soft like a maxed out credit card to scrape it without scratching. ![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/26570d1353843955-broke-off-thermostat-housing-port-expansion-tank-bleeder-hose-11-cylinder-block-face-cleaned-jpg)
Also tighten the four Thermostat Housing fixing bolts evenly. The Rubber Seal in the groove in the base of Thermostat Housing (arrowed in red) compresses as the bolts are tightened to form a water tight seal.
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/26571d1353843977-broke-off-thermostat-housing-port-expansion-tank-bleeder-hose-thermostat-housing-seal-jpg)
It doesn't need massive force to achieve this and over tightening risks shearing the bolt or stripping the thread in the Cylinder Block. The correct figure is 8-10 Nm.
#31
So I was able to get the new t-stat aluminum housing installed without too much trouble but I did not have the correct size allen head wrench to torque the housing cap on but I opted to try a channel lock wrench and tighten it as much as I could but when I turned car on coolant was gushing from the cap so I guess I wasnt able to get a proper seal on the o-ring in there.
Anyone know what size allen wrench fits on the top of the housing to tighten the cap? The cap says torque to 9nm but I feel like I tightened the cap that much with the channel lock... I guess not since niagra falls came out of the cap upon start up
All that work and still cant drive her yet!
#32
The Cap should screw onto the Thermostat Housing by hand very easily without any need to force it. The watertight seal is created by the rubber gasket being compressed inside the Cap against the top lip of the Housing body.
I can grip these by hand to tighten them sufficiently without needing to use an Allen Key.
Are the threads on the Housing body and the Cap OK?
hawaiianjag (11-27-2012)
#33
Not a brilliant Thermostat Housing pic but adequate to show the three seals:
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/26635d1354015972-broke-off-thermostat-housing-port-expansion-tank-bleeder-hose-thermostat-housing-jpg)
The seal on the left goes in the base of the Thermostat Housing. The seal on the right goes around the Thermostat. You can see the black seal already fitted inside the Cap. You do have a seal inside the Cap?
#35
#36
The OP did replace with the aluminum upgraded housing... dead on with the plastic version... they stink!
#37
thanks a lot everyone! I was able to fix the little leak with a bigger o ring purchased from hardware store. I think I overtightened the cap the first time compromising the original seal.
I got a thicker o ring and now no leaks.
Took it for a 30 minute drive with no problems so I believe it to be a job complete.
Couldn't and wouldn't have done it without everyone!
Be sure to let me know if you guys come to Oahu, Hawaii. Drinks on me at the stip club with the jag parked out front at the valet
![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
#38
Success. ![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Following a coolant flush and refill, run the engine up to normal operating temperature and turn the heater to MAX. This circulates the coolant through the entire system.
Allow the engine to cool completely and check the coolant level in the Expansion Tank. It may have dropped slightly if there was any air trapped as the system was refilled.
If necessary, top up to the base of the Expansion Tank filler neck.
hawaiianjag (11-28-2012)
#39
Be sure to let me know if you guys come to Oahu, Hawaii. Drinks on me at the stip club with the jag parked out front at the valet![Icon Razz](https://www.jaguarforums.com/forum/images/smilies/icon_razz.gif)
#40
Well I decided to floor it for the first time since the new housing and t stat to pass a few cars on the way to town and I got a low coolant light after completing the pass.
I pulled over, checked coolant and it lost about 2 inches in the expansion tank and I could see a few drops below the housing cap.... ahhhhh. I filled it up again and started car with no visible leaks. Drove for another hour and then back home another hour with no loss of coolant.
Mind you this is with a much thicker o ring that I put in there since the provided one was causing a visible leak at idle.
I am ordering a new housing cap and hopefully that fixes this leak once and for all.
