Broken fastener clips of the door card XK8. Solved for a penny.
Hello friends.
One of the smallest on harmful problems is broken fastener clips (rivet) on our XK8 door cards. It is very expensive from dealers - well, this is as always - and is not available. Only to order and wait, wait, wait. Broken fastener clip of the door card
I looked at my door for a long time, and at last I decided to pull out a white nylon insert of metal of the door. And there will remain a hole 8 mm in diameter. Nylon insert
8 mm hole in metal of the door
Instead of the original fastener clip, you can take any plastic fastener clip. 100 pieces for one dollar. The main thing is that they have a size in the narrow part of 6-7 mm, and in the wide part 9 mm. Any clips which I found on my garage 6.5 mm and 9 mm
They calmly dress in their place on the door card. And just perfectly fix the door card in 8 mm holes in the metal door.
Can you help me with my account on the forum?
Long time ago I registered as Ruslan-aka. But I can't to entry to the forum as Ruslan-aka.
The system show me the window where wroted what I banned.
I don't know whats happened. And from this I maked new registration.
Wroted in support, but have not the answer.
