Build Thread: XK8 Convert EV
#63
(I only got back to Japan from Germany and Spain yesterday!)
Unfortunately, Not much has changed other then preparing for the engine bay paint job. (Alot of sanding...)
I will get my head into a gear and get it going in March!
(I've also purchased Chademo* and J1772* compatible Charger fast charger. )
*Chademo and J1772 are the world wide standard charging inlet for the EV
#64
Repainting Enging room
As promised, I've finished stripping the engine room and scraped as much paint as possible...The original paint job was surprisingly thick!
So, Here are photos of before and after (still in middle of Priming layers...)
Will try to get it done by the end of this month!
Before
After(halfway through base coat)
Before
zecretw (03-21-2016)
#65
#66
#67
Repainting Enging room part2
More update with a paint job!
Got more done this weekend but yet to finish...(will finish this week)
Got all primer done and wet sanded with 2000grit. (silky smooooooth!)
i've started with the black paint(Honda colour code: NH731P) but only first layer is on it for now.
i've done my research and as it turns out, this honda's black is the deepest and gorgeous of all backs I can find!
2nd layer of Promer
3rd layer of Promer
4 layers of Primer.
wet sanded with 2000grid
Beginning of 1st layer of black paint!
2nd layer of Promer
3rd layer of Promer
4 layers of Primer.
#69
Dear Rui-san,
Thank you for writing up your very interesting project. Keep the great work going!
I regret I'm unable to buy your V8 because of the exobitant/prohibitive shipping regulations and costs.
I wish you the best of luck to completing your XK8 EV.
So, Update:
Let's just say Its DONE!
2nd layer done
3rd and final clear coat!
Yes, the headlight housing in green still(now I wish I did it as well) but hey, once the headlight is in, you wont see any green-ness!
Can you believe this is done with a Can spray?
PS: Technique I've used is to dip the can in hot(45 degrees C) water before use. And to make sure you have good light shining on where you are painting to see the reflection of the coating!
The following 2 users liked this post by rui:
User 070620 (05-02-2019),
zecretw (04-01-2016)
#70
#71
#73
slight delay...I was going to hook up the coupler to the flywheel but light problem has surfaced...coupler has wrong bolt pitch...Original flywheel comes with M12 1.75pitch bolts where as the couple is threaded with 1.5pitch.
Already made the order for them...
original bolt only goes in for about 2mm....
Another problem...I was gonna put the shiny motor mount to the engine mount. However, engine mount bolt is too short...so I'm gonna need to make slightly larger hole on top of the current one to make them fit!
engine mount arm is way too thick!
Oh I've also cleaned the engine mount rubber thing. (They are shiny!)
PS: Do you guys prefer big pictures or small ones like this?
michaelh (04-06-2016)
#74
Received 2,390 Likes
#77
#78
And thanks, my close ones are all well.
as of the project, I am still working on getting the motor mounted to the trans. I will do a little more work and give you guys an update!
cyber3d (04-18-2016)
#79
I'm glad to hear that your friends and family are fine. I am praying that the big earthquakes stop for a while.
I was concerned about the TCU's signals to the transmission but found some good news. You probably already know it.
Someone did an EV conversion that uses the same ZF 5HP24 that you have (I think), and he already figured out all the issues for you, and took care of them. Sounds like he had a friend do software coding for him or something.
Even better is that he made YouTube videos of the whole process.
Just in case you were not aware, here is a sample:
#80
I am planning to run MT in future tho. I'll try to solve the TCU troubles as I go. ( I can use 4th gear and Reverse and park without TCU anyway )
