Burping the cat
Hello all
Anyone know of any special procedure to get all the air from the cooling system after a drain and re-fill?
I had to change the front water distribution pipe/manifold (or whatever it is called) - the level in the expansion tank has falling slowly, temp shows normal, but just worried that there are air pockets in the system somewhere
thanks!
Paul
thanks!
Paul
remove the thermostat cap (i think its a 10mm allen head) located directly on top of the thermostat housing. since yours is a 97 it may have a chrome cap on top of it. it just pops up. then remove the coolant reservoir cap. next start filling up the engine at the thermostat cap area. once its completely full and has stopped burping air, install the cap and chrome piece. then start filling at the coolant reservoir until its full. install the cap. last remove the back of the pass fenderwell. thats where the overflow tank is and fill it up half way with just water. run vehicle till its hot then shut it off and wait till its cold and recheck at the coolant reservoir. that is the best way i know. hoped this helped.
dmatthewman
09-30-2015 10:10 AM
