Bushing parts advice
Hey everybody,
I'm replacing the upper control arm bushings on my 1998 XK8 real soon. Tell me if the bushing set in the following link is the one I need. Thanks in advance.
https://www.ebay.com/itm/151995009675
You re-use your washers so be sure to clean/scrape every last piece of old rubber off of the re-used washers or they will squeak.
Most people re-assemble the Upper wishbones a few times before they get the right assembly sequence. It's like a mind puzzle.
With the upper wishbones out, its easy to look at the condition of other stuff, like the swaybar and lower wishbone bushings or check the sloppiness of the inner tie rods.
Americain (09-16-2016)
Americain (09-17-2016)
Received 4,339 Likes
sdelliott58
09-20-2016 11:48 AM
