Butterfly Valve
Butterfly Valve
Does the ignition need to be onto to open the butterfly valve fully or is purely mechanical from the throttle cable?
I tried to clean my throttle body yesterday and jammed a piece of dowel between the throttle pedal and the driver’s seat making sure to have the kickdown switch engaged with the ignition off.
The butterfly valve was only open about 1/4 of the way. The throttle cable had been adjusted to be taught and still allowing for the snap back to the stop when released manually.
Thanks,
Karl
Thanks,
Karl
H20boy
09-04-2017 03:55 PM
