Buzzing sound at 20 MPH - RESOLVED
2001 XK8 with 70K.
Just had some major AC work done (at Jag dealer) - there was a leak in a hose that they tell me was hard to get at.
Anyway, AC works fine now however, the car has developed a buzzing sound (some sort of harmonic) when driven at exactly 20MPH.
Buzzing sound goes away by the time the car reaches 23 MPH. Sounds like it's coming from the front middle.
Any thoughts?
Any thoughts?
If the work required getting to the Heater/Evaporator Core, that involves considerable dismantling in the centre console area.
Possibly centre veneer trim panel or the centre vents loose. The veneer is bonded onto a metal backing and can set up a vibration if not firmly engaged in the securing clips
If you put a hand on these at 20MPH, does the buzz stop?
Thanks for the thought but this is not something inside the car. It is a metallic buzzing sound coming from underneath. The best way I can describe it is if there is some sort of metal shield over the exhaust system that has not been tightened enough and vibrates (buzzes) at a certain resonance
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
