C.D. Player E-01 Code
My C.D. player was working just fine. Now I get an E-01 code & it won't work. Tried green ejection button for whole casette on player & won't eject whole casett. Casette is stuck. Manual says take to Jaguar dealer which is usually expensive. Any help to resolve situation is appreciated.
I've known a few who have had this issue and ejected the CD by sliding a small screwdriver underneath the magazine and lifting it whilst pressing the green Eject button. The magazine is held in place at the slot on the base at the left. Here's the base of the magazine:
This gets the magazine out but doesn't resolve the issue which is likely to happen again.
A better approach is:
1. remove the CD autochanger from the vehicle and open the case
2. rotate the eject drive toothed gear by hand to eject the magazine
3. reconnect the CD autochanger
4. power on the radio and select CD
5. wait for it to give 'no magazine' message
6. insert the CD magazine
Provided there was no damage to the CD eject mechanism in the first place causing it to stick, this fixes it. Only done this on an XJ8 but the XK8 should be the same.
![C.D. Player E-01 Code-cd-magazine.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/18474d1480966479t-c-d-player-e-01-code-cd-magazine.jpg)
Msterieus (01-24-2018)
Tom 2005 XK8 coupe ( just bought 3 wks ago with 31K miles on it)
Attachment 18474
Attachment 18474
Thanks again!!
Tom 2005 XK8 coupe ( just purchased with 31K miles on it - near mint)
Thank you again Graham & Dennis. I used both of your methods & I don't know which one worked, but all of a sudden the cassette ejected. That's one less thing I'll need to pay for when visiting the local Jag. service dept on Monday ... having brake fluid & coolant flushed on my XK8 (2005 Platinum/black).
I did order a new Jaguar labeled cassette off the internet & will use that one just in case my original is defective. I think it'll be worth the $25. for a preventative maintenance item - if indeed that's the issue. Better than paying Jaguar service dept a wheelbarrow of money to "fix" it. Might even spray a very small amount of silicone lubricant in the changer mechanism.
If that doesn't work, then I'll get a guaranteed used one off the internet for around $100 - $150.
Tommzr
Tommzr
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Tommzr![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Tommzr
Dennis
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks for the tip! I tried the flat head screw driver trick trying to lift the cassette from the bottom but found that when I started tapping on the cassette case with the butt end of a screw driver it ejected! After cleaning everything up I re-inserted the cassette. It worked for a while but I then got the same E-01 message. I tapped it again and it ejected fine. I guess I may need to buy a new cassette to keep this from happening again.
Good evening guys.Should i understand then that the amps(above the cd changer i guess)has nothing to do wu=ith teh E-01 code ?I havea 98 XJ VP magazine stucked with 1 cd ,So if i repalce the changer i should be good ?I am trying to get this car to wher ei wants it to be - these are no longer made and i plan to keep this black beauty for years to come.If i plan to put come kickers speaker in teh trunk do i need to add additional amps ?I am in Alexandria VA and would liek a recommened location to get some electronic work done .Any suggestions / recommendations ?
Thanks- Happy Holidays.
philwarner
25
06-26-2021 05:43 AM
08292
07-09-2018 01:44 AM
FS[Western US]: JAguag x350/358 CDC Player Brackets
perezal
12-24-2015 04:20 PM
