A/C Host replacement on a 2001 MY
I have to replace the A/C Host (Compressor to low-pressure-valve) which is one piece. But as I search for this part I find only a "2-parts" Solution. Are the replacement parts because of easier fixing?
What about the work to change itself? How hard is it?
Thanks - Daniel
Thanks - Daniel
Received 2,432 Likes
Which part do you need to replace?
Getting the hose disconnected from the compressor might be challenging. Take a look at this article on Gus' great info resource:
JagRepair.com - Jaguar Repair Information Resource
I recommend replacing the receiver/dryer as part of the job even if you still have pressure in the system, and renew any 'o' rings you disturb.
Orthodixie (06-28-2018)
carelm
02-11-2017 09:53 AM
