C1175 code stored
C1175 code stored
Has anyone has experience with this. It translates to left rear wheel sensor if I am not mistaken. It only happens when cold and wet. I am thinking a poor connector connection on the sensor harness connector, but searched it and no one else has reported this concern. Oh the abs, traction and check engine lights come on witht this as well.
ok so I finally got a chance to get it up in the air and found the left rear abs harness stretched due to the way it was routed. I changed the direction so it goes over the brake line and cleaned the connector and sensor pins. While I was at it I took a look at the cogs on the axle and found them to be almost completly filled with dirt. I cleaned them off on both axles. The end result? I have no more lights on. car excellerates harder around right turns without setting the light off as well. (This part must be the tension that was on the harness) Hopefully I wont be haveing to replace the harness any time soon, as it does not look as if it is a simple subharness like the front ones.
chatmanx
09-11-2015 07:17 PM
1964Daimler
09-09-2015 11:20 AM
