Cabin Filter
Yes, the tapered wiper arm and shaft presents a problem with removal after many years. We solved this with a purchase of inexpensive tool from E-Bay vendor. Search for "tapered wiper arm puller" and many different types will be available. The one we used consists of a aluminum housing with U-slot at lower end and a plastic capped thumb screw on top. The lower U shaped housing slips around the tapered wiper post to capture arm when the screw is tightened down to press the arm loose. This does require one to remove the vinyl blanking cap first over shaft.
NOTE: Place a short strip of tape along each wiper blade on glass to use as a marker so they can be returned to original spot on glass. Remounted with anti-seize for future removal if needed.
The following 4 users liked this post by kstevusa:
Timeisrelative (09-03-2022)
2018XF25T
F-Pace (X761) / C-X17
06-12-2022 08:03 AM
