Caliper bolt wont come off
Running out of idea's, I have a 14" breaker bar that I have stood on and the the bolt still would not budge. Guessing the last time the brakes were done, they used an impact wrench with loctite. The rears were a breeze, but these fronts are kicking my butt, I am going to try some kind of anti-seize spray, but short of a sledgehammer, I do not know what else to do.
Finesse over Force. A five foot breaker bar is a recipe for one sheared off brake bracket bolt. Heat, vibration, PB Blaster, impact wrench, back and forth tightening/loosening are your friends. Just using the biggest bar you can find is going to result in another post about how do you remove the broken section of the bolt.
If you don't have access to an impact gun, use a sledgehammer. Smash the head of the bolt with authority as if you were attempting to drive in a nail with a single stroke. Use the heaviest headed hammer that can be swung in the space available. Strike with the hammer, attempt to loosen. Repeat until it breaks free; which given persistance, it most certainly will.
Dan
Dan
baskervillema
10-01-2015 06:43 PM
