There should be 2 clips glued to the glass on either side and a mating feature on the light assembly.
I gave up and used a bit of rubber hose to wedge the light in place. It is behind the speaker cover and I can’t even see it when looking in the mirror.
I currently have a rolled up microfiber towel holding it up. Never thought about rubber hose. What diameter did you use?
The clips were broken on mine so I put black acoustical sealant around the edges and held it in place with a roll of paper towel until it was dry. You can't see the sealant from either side of the glass and it has lasted a year with no signs
of letting loose. I can still cut the rubber sealant with a knife if I need to get at the light to change bulbs.
Mines held in place with a wedge of wood smh. Don't much like the idea, but I painted the housing and the wedge black, so it doesn't really show at all.
For my light, I used a couple of short strips of velcro on the bottom. It grabs hold of the package shelf cover and doesn't move at all, but can be removed for service if needed.
By chance does anyone have a picture of the two clips?
