Cam Chain Tensioners
Old 01-03-2011, 10:32 AM
EZDriver's Avatar
Smile Cam Chain Tensioners
Hello to All and Happy New Year,
I do hope all of you that have a lot of experience with XK8/4.0 Liter engine will respond to this thread.
I am planning on replacing the secondary tensioners on my 2000 XK8 that has 40K miles on it. I can do this readily after reading all the forum info on the technique. No problem there. But, of course, I will not be messing with the primary chain and tensioners. My question is.....Has anyone ever had a failure of the primary system that resulted in valve damage with out a warning noise in the front of the engine. From what I have read it seems like that the secondary tensioners are the main problem. And if I replace them I will get many years of service from the car since I only drive it for fun and don't put many miles on it each year.
Input on this subject will be greatly appreciated.
EZ 2000 XK8 1995 XJ6 Long EZ
Old 01-04-2011, 12:56 AM
Y2K XKR's Avatar
I have a similar situation - 2000 XKR with 30K miles and I only drive it 4K per year or so. Everthing I've read points towards replacing ALL the chains and tensioners for a 100% fix of our model year's timing chain weaknesses. I didn't have the time or money to make that happen right now so I went with the upper tensioners only this past weekend which by all accounts should get me by for quite a while. In 3 to 5 years I plan to replace the whole lot including water pump, thermostat, belts, and radiator hoses. If you have the cash and the time I vote do it all now. On the other hand if you're strapped for time and/or money you can get by with just changing the uppers for now. I added a few lessons learned to Simon's secondary tensioner thread. Best of luck whichever way you go.
Ken
mikiep
12-20-2019 07:37 PM
Jässe in Pälkäne
10-02-2015 05:38 AM
millertic
09-30-2015 08:11 PM
JAMES1944
09-29-2015 11:58 AM
Quick Reply: Cam Chain Tensioners
