Cam Cover Baked On
Old 07-08-2018, 12:25 PM
max224's Avatar
Default Cam Cover Baked On - RESOLVED
All 12 bolts are loosened and it appears that the cam cover is pretty much baked on or has too much sealant on the gasket. I'm replacing the cam cover because of a broken breather fitting so damage to the cover is not my primary concern, damaging the cylinder head or ending up with debris dropping into the engine is. Anyone had the same problem and found a way to remove the cover? I have a heat gun if you feel that that would help.
Thanks,
Old 07-08-2018, 12:26 PM
Received 2,665 Likes on 1,829 Posts
Use a rubber mallet to tap the cover and a plastic wedge between the cover and head surface.
max224 (07-08-2018)
Old 07-08-2018, 01:14 PM
max224's Avatar
Thanks, I'll give it a try.
Old 07-08-2018, 01:25 PM
Hopefully you've also removed the two bolts in the centre of the cover between the spark plug wells.
The following 2 users liked this post by NBCat:
motorcarman (07-08-2018), toaster (07-08-2018)
Old 07-08-2018, 02:15 PM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
That's the problem, there are 14 not 12.
The following 2 users liked this post by RJ237:
max224 (07-08-2018), toaster (07-08-2018)
Old 07-08-2018, 03:37 PM
max224's Avatar
That would seem to be my problem. The cover has 5 bolt holes on each side and two on the front. The cam cover gasket looks identical. Those last two bolts (nuts?) must be well hidden (at least I couldn't find them). Are there two more without corresponding bolt holes in the cover or ?
Old 07-08-2018, 04:02 PM
michaelh's Avatar
Received 2,400 Likes on 1,556 Posts
max224 (07-08-2018)
Old 07-08-2018, 04:56 PM
max224's Avatar
Thanks Michael and RJ; I somehow missed bolts 1 and 2 which I quickly found (duh) after it was pointed out to me. The bolt tightening sequence is invaluable and greatly appreciated. Been awhile since I worked on my Jag and forgot how much fun it is (if you have a universal joint as a wrist). The driver's side awaits, which I understand is even more difficult!
john50
05-28-2013 07:08 AM
Steve W
XJ40 ( XJ81 )
12-07-2012 10:08 AM
JagYour
04-17-2011 10:29 AM
bootleg
07-03-2008 02:45 PM
Quick Reply: Cam Cover Baked On
