Cam cover bolt removal problem
Hi Folks,
Looking for a bit of advice. I got some spare time yesterday so decided to remove the cam covers to get at the leaking plug and cam cover seal.
Problem is I cant seem to get proper access to the bolt on bank 2 (rhs when facing car) thats on the bottom sode of the cam cover underneath the coolant bottle.
Access is poor and I have tried 3/8 and 1/4 socket set, open ended and ring spanners.
Any tirck to getting this one out??? 10mm Crows foot??
Even if I do get it out, how are you supposed to torque these up afterwards as theres no way my torque spanner will fit in.
Any help appreciated
Mike
Mike
No Steeevo,
Just no time. I work, the missus works, 3 kids with the youngest under 2. Im an expert at cooking but the kids say I must be allergicto the vaccum cleaner! More chance of me vaccuming than getting time on the xk8... meanwhile theres a capri in the garage needing valve stem seals, a mk1 escort that needs recommisioning and a daily driver bmw 320 vert that has the odd fault code or two!!
Mike
Mike
I moved my coolant reservoir it was one bolt if I remember correctly, a couple of things to beware of.. the plastic cooling lines can be brittle, I'd broken one cleaning the engine on a different day, also beware of the low coolant sensor that plugs in the bottom doesn't pop out or get damaged. Also used 1/4 universal and extension.
1/2 in torque wrench with 1/4 in step down to 1/4 in wobbly to 3in extension to 1/4 in wobbly to socket. Bit of a Frankenstein tool but it worked. I've been known to hack a spanner in half when I can't get one in. Helps if you have hands like a 12 year old girl, But being Irish myself I doubt you do!
MC36
US Lower Atlantic
09-01-2015 07:34 PM
