Cam cover gaskets
Received 2,390 Likes
According to JEPC, the changeover from the 'pair of specs' plug seals and, I think, the fatter cam cover gaskets, was by engine number (>9810290000) which runs into the 99MY?
If it is an older cover, you should be able to see the channel in the cover moulding where the rubber piece joining each pair of seals fits. Can you compare the two?
motorcarman (05-25-2020)
EsRay
12-08-2017 04:42 AM
