Cam Cover Repair
Old 04-30-2014, 09:03 AM
jimmiejag's Avatar
Default Cam Cover Repair
One of my cam covers has a small portion split from the it, but remains held in place.
I am going to replace both cam cover gaskets and inspect the secondary tensioners to see if they have been upgraded which may involve more dis-assembly, depending on the results of the inspection.
My question: Has anyone used glue/cement to repair a plastic cam cover successfully? If so, what did you use?
Thanks,
Jim
Old 04-30-2014, 09:17 AM
aode06's Avatar
The oil and heat eventually breaks down most repairs. However, I have found that after using break cleaner in the area,rubberized truck bed coating spray adheres the best for many years.
To make it look good, I would have the cover totally de-greased,spray several coats on the whole cover,then follow up with coat of black paint.
The coating is pretty much bullet proof.
preuss2 (05-01-2014)
Old 05-01-2014, 11:38 AM
Rey's Avatar
Rey
Rey is offline
I have used JB Weld to successfully hold an aluminum corner of a Honda transmission that was knocked off by my ineptness. The repair held for 50K miles and several years to when I sold the car.
Before, I used the JB Weld I called them for advice. They are very helpful.
1964Daimler
10-03-2015 12:18 PM
1LowCat
09-14-2015 07:51 PM
Dickie_L_J_O
09-13-2015 07:44 AM
KarimPA
09-12-2015 08:15 AM
jaggermang
09-08-2015 07:07 PM
Quick Reply: Cam Cover Repair
