Cam position sensor
Fn2, welcome to the forum.
It would be helpfull if you mentioned what model, year and engine you are inquiring about. Put those details into your signature, using the "User CP" option in the top left tool bar.
Also this is an introduction section, please go to the correct model section to post any technical questions.
Enjoy all the site has to offer!
Fn2damax (02-16-2012)
Received 6,320 Likes
Received 9,010 Likes
See attached. The engine transitioned right around your model. Not sure which one you have so I posted both types.
The following 2 users liked this post by WhiteXKR:
Fn2damax (02-17-2012),
jagslinger (10-12-2014)
The sensor is at the end of bank 2 (L/H Drivers side), works off the inlet side so will be on the inside of the head, you cant miss it at the back, you will need to take off the fuel connector going onto the rail to remove it via a 8mm hex bolt, just slides out, if its a little tight that will be the O ring that seals it in, just give it a wiggle!
Guy-Pierre Boucher
09-16-2015 05:55 PM
Dickie_L_J_O
09-13-2015 07:44 AM
