Cam tensioners
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
`I just replaced the upper cam tensioners on my 01 XKR. Ordered the tensioners and bolts from Lincoln, part #s 2W9Z6K254CA and 2W9Z6K254BA. They got me the wrong bolts, they were as long as the old ones but had more threads, so I was able to shorten and use them. I wont give that part #. The parts cost me $132 wholesale. Got after market valve cover gaskets on line for $56, they are rubber not silicone rubber as origional. Could have reused old ones as they last forever. I wiped a little O2 safe silicone on the spark plug hole gaskets before installing. I borrowed Ford Tool Kit from my local Lincoln dealer. Kit # TK 2000 AP, It contains all special service tools for the Jaguar V8. Lincoln calls it a 3.9L. Actually the job was Quite easy, nothing was especially difficult to get at with proper tools. Valve covers came out with minimal removal of other parts. I don't think it should take any competent person more than 4 hrs to do the whole job. It wouldn't take much to fabricate a cam locking tool by drilling a piece of bar stock and you could stick a couple of bolts or round stock in the sprocket holes and just lever on them with a large screw driver to tension the chain. Be sure to copy the instructions from your JTIS and follow them, it isn't necessary to use the crank locker tool. At 68K my tensioners showed little wear.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
`I just replaced the upper cam tensioners on my 01 XKR. Ordered the tensioners and bolts from Lincoln, part #s 2W9Z6K254CA and 2W9Z6K254BA. They got me the wrong bolts, they were as long as the old ones but had more threads, so I was able to shorten and use them. I wont give that part #. The parts cost me $132 wholesale. Got after market valve cover gaskets on line for $56, they are rubber not silicone rubber as origional. Could have reused old ones as they last forever. I wiped a little O2 safe silicone on the spark plug hole gaskets before installing. I borrowed Ford Tool Kit from my local Lincoln dealer. Kit # TK 2000 AP, It contains all special service tools for the Jaguar V8. Lincoln calls it a 3.9L. Actually the job was Quite easy, nothing was especially difficult to get at with proper tools. Valve covers came out with minimal removal of other parts. I don't think it should take any competent person more than 4 hrs to do the whole job. It wouldn't take much to fabricate a cam locking tool by drilling a piece of bar stock and you could stick a couple of bolts or round stock in the sprocket holes and just lever on them with a large screw driver to tension the chain. Be sure to copy the instructions from your JTIS and follow them, it isn't necessary to use the crank locker tool. At 68K my tensioners showed little wear.![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
I agree with you on all your points and for the sake of those still contemplating this job. I've fabricated my own fixtures for the upper tensioners on the first one I did and still use them today, including the spanner. Agree too, the crank lock pin is not necessary for secondary tensioners, although use it if it makes you feel better, won't hurt either.
The only item on which I part company with you is the cam cover seals. These, more realistically, have a lifespan of around 60K miles, they harden from the constant heat cycles and will frequently start leaking. Also I always install the seals dry, but would only use an O-Ring Silicone (not a gasket sealer), if I was to use anything. The key to proper sealing is proper torque of the cam cover bolts. Too tight will crush the rubber/steel inserts and distort the plastic cam covers, then, even new seals will leak.
After reading all of the information on the forum I decided to take a look at the tensioners in my '99 XK8. I have 55,000 miles. Was I surprised. BOTH secondary cam chain tensioners were cracked. One the whole way through from top to bottom and the other, all the way through about 3/4 of the way from top to bottom. Two of the rails were split in two places. I think I saved myself some expensive repairs down the road. I was actually fun. While I had everything apart I went ahead and replaced the thermostat, water pump and all of the heater hoses. I thought 11 years was more than enough to ask of those parts. All went well.
+! on the gaskets don't live forever, we used to replace them quite often when I worked at a Lincoln dealer. The gaskets will shrink and harden over time and leak.
-1 on using silicone sealer on almost anything. Peeps seem to think it's the second coming but when your reputation and paycheck stands on the test of time you'll suffer.
One popular brand is Permatex Silicone RTV. You only need the smallest tube they sell.
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
