Cam/Valve cover gasket?
I replaced my cam cover gaskets with new "Genuine" Jag parts when I did the tensioners last year about 3,000 miles ago. Now the left rear is leaking again...dang-it. I read on the Forum that the following:
FEL-PRO Part # VS50724R $38.79 was a good replacement.
I've always trusted Fel-Pro they make good gaskets. However I just read, on the Forum, that the 3.9 Lincoln gasket is not the same.
Rockauto http://www.rockauto.com/catalog/x,ca...parttype,10710
this is for an 2001 Lincoln 3.9 LS
So what is the scoop, is it or is it not the same for the 4.0 Jag engine.
1964Daimler
09-09-2015 11:20 AM
