Camber out of adjustment on front right only
I was replacing a wheel sensor and noted that my right ( passenger side NA ) tire was wearing on the inside edge. Left side is normal. Ny local shop says the camber is off on that side but they don't know why or how to adjust it. Any insight or ideas ?
The following 5 users liked this post by cjd777:
Dr. D (08-26-2024),
giandanielxk8 (08-26-2024),
Jon89 (08-26-2024),
kstevusa (08-26-2024),
motorcarman (08-26-2024)
Barry, to give you an idea of the condition of the bad one, have a look at the good side at the top. Right above the spring is a plate it rides on and above that a foam, rubber, sponge looking bushings. If worn it will only be 1/4 inch or less wide between that spring plate and the top of the mount. It would be in the 1/2-inch (13MM) range if still in a serviceable condition.
Now look at the side with a problem and if in that 1/4 inch (8MM) or less, sometimes not even something you can see any distance between the plates.
Hope that helps.
Hope that helps.
