Camber wear front tire question
Pistnbroke (09-21-2022)
Tracking is out ..they are running toe in so the outer edge rubs. You need to find the right figure and take it to a shop to have it adjusted . Usually the length of the track rod is in your case shortened. Check when you get it back that the steering wheel is still central in straight-ahead driving . Lazy shops only do one side
Johnken
02-26-2019 09:20 PM
