Camshaft locking tool dimensions?
Old 06-27-2021 | 06:54 PM
NorXKR's Avatar
Default Camshaft locking tool dimensions?
I will soon change the timing chains and tensioners on my 2000 XKR and thought I could make the camshaft locking tools my self.
It would be nice if someone could tell me the dimensions.
I do have the special tools for the crank pulley, but do not want to spend the extra cash for the locking tool that I will use only one time.
Old 06-28-2021 | 04:28 AM
kansanbrit's Avatar
I think on that engine you are just making sure the flats are in alignment so a straight edge can be used to check it once you have the chains on.
Old 06-28-2021 | 06:22 AM
Coventry Foundation's Avatar
If you do make a tool make sure you make it from steel. Aftermarket tools made from ALU. will allow the cams to turn (reported many times) and the result is not satisfactory. Best of luck.
car5car
09-22-2018 12:15 PM
Doug Dooren
10-05-2017 06:53 AM
Jestocost
US Western
06-19-2017 10:09 PM
cyber3d
04-22-2016 02:52 AM
Quick Reply: Camshaft locking tool dimensions?
