Camshaft upgrade!
Old 10-08-2012 | 02:42 AM
XKRacer's Avatar
The easier way is to gind the dwell on the bottom of the lobe and fit lash caps, I know a XKR that gave an extra 3mm lift, there is a big but though, the engine timing needs to be altered as the over lap was too much and lost all the gains and the car was worse...... Can't remember off hand what the difference was but it does need to be set up properly
Old 10-08-2012 | 09:34 AM
rsigue's Avatar
Default Yeah But!
I think i will leave that to the experts who have all the right tools to know exatly what duration and lift are. Looks like a camshaft upgrade is the only upgrade u can make to the 4.0 with out haveing to change ecu, tcm, man jag really makes it difficult to enhance thier product when we feel its lacking something. Dont get me wrong the xk is and awesome unit but . Well i leave it at that......... I will squeeze out a few more horses . And start looking for a tcm tuner so that i can change out the rear gear ratio for something more to my likeing....... will update when project gets under way. Starting to consider either a xkr or corvette might be an option if power is what i really want.........
Old 10-08-2012 | 09:58 AM
SteveM's Avatar
Cams for forced induction should be different than NA, as too much overlap will cause the incoming air/fuel to be blown out the exhaust.
Old 10-08-2012 | 10:39 AM
Cambo's Avatar
With the 4.0L they may well be, given that the N/A cars have VVT and the S/C cars don't.
That was also the case with the 4.2L to begin with, BUT the last series of S/C 4.2L engines also got VVT and the cams were then identical to the N/A engine.
Old 12-14-2020 | 09:52 PM
Dwbridge87's Avatar
Hello where can I get performance cams for my 98 xk8 engine?
Who is the guy that was modifying the Cams?
Does he still do them?
Thank you
Old 12-15-2020 | 01:46 AM
avos's Avatar
I have done mine with Catcams in Belgium : CAMSHAFTS | CAT CAMS performance camshafts
Old 12-17-2020 | 10:41 PM
Dwbridge87's Avatar
Did you have to shime/ readjust the lifters?
  #28
Old 12-18-2020 | 01:39 AM
avos's Avatar
Yes you do, they are called lash caps, as described in post #21 by xkracer.
Old 03-29-2024 | 05:25 AM
louie sot's Avatar
Default Xj8
Originally Posted by rsigue
If your interested im makeing a camshaft upgrade in my 4.0 xk8, foumd a guy in alabama whose being doing shafts for years. I will send the shafts to him, he can reweld the shafts then upgrade the duration and lifts to give up to 15% more power. Spoke to him and he sounds like he has lots of experience with jaguar perfformance camshafts. Has already done a couple of xks . Couldnt find anyone who sells them but this guy If anyone has any info on someone else get back with me. Roughly 43 more horses . Ive done that in chevys before so i know that its real , so only thing to do is get them to him and see if it will work on jaguars...
have you got the guys email address about the came upgrade for my xj8 4.0
  #30
Old 03-29-2024 | 07:39 PM
stevis05's Avatar
To user jgaxkr, a quote from your post “Instead of selling it and buying an R.....If u want more bottm end all we have to do is change the rear end gears from the 3.06 to a 3.46 this will give us some ump and may be we could spin a little tire ,.”
well I don’t know about everyone but if I push the “asc off” button, the “s” sport button, and at a dead stop floor it my 97 xk8 will spin tires. If I turn a hard left from a dead stop and do the same (floor it ) I will spin so hard I lose control and end up in someone’s front yard. I still have stock motor with nikisil liner but just did my timing chains. I got 69k miles on it.
  #31
Old 03-31-2024 | 11:56 PM
auburn2's Avatar
Originally Posted by pomosv
This effect is compounded when you throw forced induction such as an XKR supercharger in the equation.
On an XKR I would think higher boost is a much easier way to get more performance, while also being more daily driver friendly.
King Charles
10-16-2015 02:25 AM
1100me
10-02-2015 12:49 AM
Manjag
10-01-2015 06:34 PM
42Ajd
09-26-2015 08:04 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: Camshaft upgrade!
