Can the back windows be rolled up with the top down?
#144
Rear quarter window control
White XKR,
Could you post a list of the part s, ie. mfr. and part #'s for rear quarter window control, using existing Roof Switch ?
As well;
Reverend Sam,
Could you make your install video available online ?
I am a new member from Canada and find this site VERY helpful.
I have had a 2004 XK8 fire engine red convertible for over 5 yrs now with
'absolutely no problems' (knock wood). As well I have a Hard tonneau cover which makes a dynamite statement when the top is down.As soon as I am allowed, I will make pictures available on the site as soon as I am allowed..
many thanks
Stan I (Stainless)
As well;
Reverend Sam,
many thanks
Stan I (Stainless)
#145
White XKR,
As well;
Reverend Sam,
many thanks
Stan I (Stainless)
As well;
Reverend Sam,
many thanks
Stan I (Stainless)
It has the instructions and sources for the parts. I also have a siginificant supply of the relays with built in diodes (so you do not need to add them externally), which I can sell you at my cost (about $2) plus shipping.
I suggest that you go to the welcome area and welcome 8 new members and then you wil be able to access all of the riches on the forum.
#146
Stan...it looks like you should have access to the writeup ( https://www.jaguarforums.com/forum/xk...e6/#post333423 ) now. Let me know if you have any more questions.
#147
I have installed the mod allowing the rear windows to roll up with the top down, but sometimes (pretty regularly, actually) momentarily pressing the "top up" switch will not start the rear window-up sequence. If I hold it down long enough to run up a little top hydraulic pressure, then back it off, the windows work on the next try. I don't know if this is a glitch unique to my installation, but the suggested kill feature would mess up my little workaround unless it only applied to the remote operation.
This may or may not be related, but the part of the window circuit that drops them when you begin to raise the roof has never worked. I haven't had time to check the wiring yet.
Cheers,
Cheers,
The auto-window drop should work..definitely double-check your wiring.
XK8+XJ8L (08-24-2011)
#148
#149
Originally Posted by WhiteXKR
I have seen this occasionally, though you are the first to report it to me. My theory is that the microswitch that detects the top is down is either flaky or needs adjustment in some cars. I will try to look into the issue further this weekend.
Short of replacing the entire RH cylinder, it seems like your workaround of starting and reversing the cycle before raising the rear windows may be the best way to go.
XK8+XJ8L (08-27-2011)
#150
Well, I confirmed that the top down sensing microswitch intermittently goes open circuit sometime after the top down cycle ends on my car. I opened it up to have a look and discovered that the switch is sealed into the RH cyclinder and is non-adjustable.
Cheers,
#151
#153
#154
Thanks for all the info regarding the rear quarter windows. I'd like to do that on my 2006 convertible but I can't see any wires that match the colors you mentioned. Also, the yellow box where the wires are is in a slightly different spot and the box detaches from a clip for easier access.
#155
I just verified the colors and they should be the same on a 2006. The only difference is the telephone connector in the console with the brown/red wire is an 18-pin connector starting in 2003, not a 14-pin connector .
One thing that throws some people off is that the wires in the car have thin colored tracers, not bold stripes like in my diagrams. Sometimes the wires in the car need to be twisted 180 degrees to see the thin stripe (tracer) on the backside.
#156
#157
Have you downloaded the .pdf from https://www.jaguarforums.com/forum/xk...e6/#post333423 ) ?
Pin numbers and position descriptions are in the drawings in that .pdf
Also if you are just adding the switch without the autodown feature as discussed earlier in this thread, I strongly recommend you reconsider and implement the autodown as described in the .pdf or you may damage your convertible top seals.
#158
Thanks again. That way looks a bit too complicated for me. The plain switch would be better. The top on my car is always down anyway. My car stays in the garage all 3 days of the year that it rains here in Arizona. Once again I looked at the wires and they are not the same color as in Reverend Sam's video. I guess I'll just leave the windows as they are. Thanks.
#159
#160
Issue with triggering roof up sequence
First, many thanks to all contributing to this thread especially WhiteXKR and Rev Sam. This is an absolutely terrific mod!
I installed both, the 'Rear Window Raise using the Roof Up Button' and the 'Autodown Rear Window Drop' according to WhiteXKR's write up. I mounted the relays and timers for both mods in the trunk close to the stereo. That way I only had to run one wire from the center console to the back tapping into the 'Roof Up' button line (there's more space in the back and it's easier to get to).
Maybe it's because of that set-up that I ran into the following issue: Even when held down for a longer period of time the 'Roof Up' button wouldn't trigger the roof up sequence anymore. With the 'Roof Up' button pressed and the relay triggered the voltage on the wire connecting to the switch was around 3V vs. the 0V it should be as the switch connects it directly to ground. That seemed to be too much for the Body Processor Module to trigger the roof up sequence. An additional resistor of ~20 Ohm between the relay coil (pin 85) and the connecting wire brought the voltage down. Everything works perfectly now! Thought this would be worthwhile sharing in case anybody else experiences similar issues.
