Can I do a bake job?
Old 10-10-2008 | 07:50 PM
brgjag's Avatar
Default Can I do a bake job?
97 XK*, are the front pads easy to replace on these? I have done disc brakes before on other cars in the past, is this car doable or should it be left to a professional? What about the back pads? Rotors seem fine, no shake or wobble when you hit the brakes. I just suspect the pads are about done.
Old 10-11-2008 | 03:12 PM
H20boy's Avatar
Default RE: Can I do a bake job?
Definately a DIY job brg. Nothing henky at all on this car. Straight forward.
Old 10-11-2008 | 08:24 PM
brgjag's Avatar
GOOD. Thanks
Old 10-15-2008 | 10:27 AM
Brutal's Avatar
its really depends, if you dont burn toast or burn water baking is easy
brakes arent bad either
Old 10-15-2008 | 12:07 PM
KAZsam's Avatar
What kind of bake job are we talking about? sponge cake, cookies, souffle? Wait for 21 to reply I think he is remodeling a kitchen
Old 10-16-2008 | 02:27 PM
Mr_Miami's Avatar
While your baking, I like cupcakes.
Old 10-18-2008 | 05:56 AM
Campeon's Avatar
Old 10-18-2008 | 07:58 AM
remosusa's Avatar
Place cookie dough on 2 different baking sheets,set oven to 350 for 30 minutes, put in the first baking sheet. Now change the pads on the drivers side, when the oven dings, you should be done with the drivers side. Reset the timer and start the second batch of cookies, then start on the passenger side brakes. When the oven dings, you should have new brakes and a batch of cookies.
Old 11-24-2008 | 01:29 AM
GreenJewel's Avatar
ORIGINAL: BRUTAL
What is used to remove the caliper bolts so I can change the pads? They appear to need a hex wrench. What size? Metric or ???
Also what is a good pad to use? I just bought this 2000 XK8 yesterday and the front pads need replacing.
Old 11-24-2008 | 10:56 AM
whiteSTR's Avatar
Be careful when doing your fronts and rears at the same time.. the master cylinder has a tendency to overflow from all of the pistons being pushed back in and brake fluid is like paint stripper.
Old 11-24-2008 | 12:03 PM
Brutal's Avatar
7MM IS THE HEX SIZE FOR THE PIN SLIDES ON THE CALIPERS
Old 11-26-2008 | 09:18 AM
noonblueapples's Avatar
I figured it was bake job like a burn out
Old 11-29-2008 | 09:43 AM
GreenJewel's Avatar
Thanks a lot. Job completed.
adam699
10-13-2015 05:53 PM
Nic1635
10-02-2015 01:30 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
millertic
09-30-2015 08:11 PM
N3yyz_XJR
09-27-2015 11:26 AM
Quick Reply: Can I do a bake job?
