Can I make a pre 2001 front buckle work with a 2003 XKR seat? (2 vs 3 wire setup)
Hello everyone.
A few days ago my 2003 XKR's driver side buckle disintegrated. I tried to put it back together but it actually broke to smaller pieces and now it is not repairable.
I bought an aftermarket buckle that I thought was compatible (there are many cheap ones in eBay) but it seems that they are compatible only with older models and not with newer XKRs (100). The original one's cable has 3 wires (Red, White, Yellow) while the after market comes with 2 (Red & Black) and a different connector. Doing some research I saw that the aftermarket is similar to older models.
Is there a way to make it work or should I find an original one (discontinued and can't seem to find online second hand).
Also will it work if I do not attach the warning cable or is there a way I can connect or short circuit of the old wires to the new connector so there are no fault lights and still have airbags etc working?
Thanks in advance for your help...
I am attaching a pic of the new aftermarket buckle:
XK8 Aftermarket front buckle
And one similar to my 2003 XKR that I need...
2003 XKR front buckle
Most of the Wrecking Yards have heard this Story and are charging up to $300.00 just for the Buckle Part...(Used)! I sure wish Someone would come up with an answer to this problem!
Please let us know if you have found a work-around! Also, has anyone found a way to take the Buckle apart without breaking it? That would be a great way to fix the problem! The Glue is so strong that it breaks the Plastic Buckle.....Any ideas?
Billy Clyde @ Cinco Ranch
sossybaby & Pistnbroke,
Thanks for the idea! I bought one of the Belts from some Junk Yard in San Franciso for $300.00! Now I see that I have to remove the Seat to make the switch....With sossybaby's suggestion I will be able to just switch the cover!
Thanks very much!
"Puerto Rico" why haven't you done this? A "Good Dentist" should be able to cast a "Plastic Buckle Cover" It could make you some Money!!
Thanks very much!
Thanks very much!
Thanks very much!
Hi guys just a heads up, finally I bought a pair of original used ones (to have a backup in case the other breaks too) from http://autoreservejaguar.com and everything works fine now...
G./
G./
