Can The Jag Forum Collective Diagnose This? My Indy Can't (yet).
My kitty has an odd noise that occurs intermittently only at speeds greater that about 40 MPH and under a light acceleration. From my listening point in the driver's seat, the origin seems to be behind me centered under the rear seats. It is a light sound, like a metal rubbing on metal. It is not a grinding sound.
I suspected something in the drive shaft / u-joints / differential but my independent mechanic went through it and hasn't identified anything wrong. He's heard the sound too and told me the intensity isn't anything to worry about (for now).
I don't like things like this as it shouldn't be making this kind of noise and I'd like it corrected before things get worse. For sure Murphy will raise his ugly head on my next trip to Las Vegas (Dec 23rd) right in the middle of Nowhere, Arizona (a real place BTW) and have the back end of the kitty fall onto the highway.
So, can the collective minds of Jaguarforums.com come up with a diagnosis?
Thanks in advance!
Scott
Thanks in advance!
Scott
I'll ask about that in the morning when I go to pick it up. This guy is supposedly a Jaguar specialist. It will be a good test!
I disagree with your mechanic, no noise in the drive train should be left unchecked. I lost a seal in my vette rearend, you can imagine my surprise when at 30 mph my rearend locked up and I skidded to a halt, lucky for me I was slowing for a light and no one was behind me.
Check for fluid leaks around the tranny tail housing and your center chunk (rearend where driveshaft connects to rearend).
beg3yrs (12-06-2011)
Yes, a worn out ujoint can make a noise, but it usually happens when you first accelerate. to me I would say put the rear up on stands or a lift and start the car and run to over 40mph, my bet would be you are low on fluid in your rearend(not that rearend) or maybe the rear tranny crossmember is loose or the rubber mounting is broken.
I disagree with your mechanic, no noise in the drive train should be left unchecked. I lost a seat in my vette rearend, you can imagine my surprise when at 30 mph my rearend locked up and I skidded to a halt, lucky for me I was slowing for a light and no one was behind me.
Again, many thanks.
Scott
Thanks in advance!
Scott
Thanks in advance!
Scott
Mine is in a 1997 XK8. Let off the gas and kitty rolls smooth.
Lightly accel and it is an annoying metallic scraping sound.
However, now that you ask, I have an update on the symptoms: Originally this only occurred while accelerating under light load between 40 and 45 MPH with the transmission in "granny mode" (not sport mode). I had not had the symptom in sport mode. A few weeks ago while driving up the Cajon Pass (I-15 toward Las Vegas from San Bernardino/Riverside) in sport mode, the same noise was heard but this time only around 65 MPH.
Somehow in my mind this would not be a U-joint problem as the symptom changes with the transmission mode.
Any thoughts? Gus???? H2OBoy?? Reverend Sam??? Others???
Scott
One piece shaft with a jurid coupling, instead of a universal joint, at the forward end. Here's one @ eBay: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
beg3yrs (03-11-2012)
I made a mistake in my post..it was not a cracked flex coupling but the bearing in the tail of the transmission that was cracked and needed replaced. That's what was making the grinding sound. I got my bill out and reread it. The shop found the problem by putting it up on a lift and running it at various speeds.
It seems, based on forum responses, this symptom has multiple potential causes. If you haven't read the related posts, I've had this to two different Jaguar dealers (Royal in Tucson and Gaudin in Las Vegas) as well as my local independent shop.
Gaudin found the motor and transmission mounts were out of sorts. The tranny was sagging and we hoped replacement of the mounts would straighten things out. While everything is nice and perky now, the noise still persists.
Royal found and fixed a few other minor things (missing bolts in a bracket, misaligned heat shields, etc), however the problem still persists.
The noise is difficult to reproduce on a lift (we even tried dragging the brakes to create a load) and the next step would be expensive tear downs. We've decided that since I've got seven months left on an extended warranty (which doesn't cover diagnosis) we'll let this go a while longer to see if the problem becomes more persistent. My only worry is something utterly failing while on a road trip.
Meanwhile, I keep working with this wonderful forum looking for others who have been through this and solved the riddle.
Personally I keep going back to something in the transmission as the MPH required to create the sound changes depending on the transmission mode (40-45 MPH in granny mode, around 60MPH in sport mode). If you take the transmission out of drive and put it in fourth, the sound does not occur.
I haven't watched the tachometer to see if it is the same RPM whether in sport or non-sport mode. I will now.
Thanks!
Scott
Hey Reverend Sam ... what does your tach show during your buzz???
![Icon Pimp](https://www.jaguarforums.com/forum/images/smilies/icon_pimp.gif)
