Can leaving the hood open kill the battery?
Seriously, I'm hoping there is some sensor that remains on that may have caused my battery to die over the course of ten days sitting with the hood open in my garage. I just went out there to fire it up to test for another problem and the battery was dead as a door nail (it's a brand new battery, as of September).
This is the first time I'm noticing any slow leaks; just trying to eliminate the obvious before delving further. Thoughts? Is there a magic gremlin in the hood latch?
Bob OB (12-19-2013)
There is no under hood light and therefore no sensor that I am aware of that would drain the battery. Did you leave the key in the ignition switch over that time? That prevents the systems from going into a 'sleep' state. Without that there is enough electrical drain to have pulled the battery down.
Bob OB (12-19-2013)
I have left mine open, closed but not latched waiting for parts. Never had a dead battery. If you start the car with the bonnet open, it will state bonnet open on the dash. If the boot is open the lights turn off but will still give you a warning on the dash. So I would think with the ignition switch off there would not be a power drain. But I have read on the forum that the car being unlocked would drain the battery, I have never locked the car in the garage and it has never been an issue. But this is a jag, anything is possible. Personel I think your battery drain is not related to the bonnet being in latched. Jim
The following 2 users liked this post by berlin1977:
Bob OB (12-19-2013),
Jerry.dillon (07-01-2016)
I was advised by my dealer to keep the car locked, whenever it is not being driven, in order to minimize (or eliminate) battery drain.
Can you open the hood/bonnet, when the car is armed, without triggering the alarm? If not, there must be a sensor.
Bob OB (12-19-2013)
Hi.
There is a sensor, a microswitch in the RH bonnet latch. This gives you the hood open warning.
If this is connected to the security system is somewhat unclear to me.
Try to lock the car with the remote with the hood/bonnet open. If it locks you should be ok.
If not. you will have a slight battery drain as the car doesen't go fully asleep.
Bob OB (12-19-2013)
It shouldn't be a problem though, I have left the car with the bonnet entirely off for weeks without an issue.
Bob OB (12-19-2013)
I trickle charge my battery with the hood open (unlocked) After a few weeks the charger stops charging for a couple of days because full load reached.
The car is locked; The moment I touch the outside door handle, charching light lights up immediately.
And all other explanations I have experienced (like leaving the door open, key in the lock, etc)
Bob OB (12-19-2013)
The following 2 users liked this post by smithtrevor:
Mr. Feathers (12-18-2013)
Wow!!! I'm sure glad I read this as I keep my car unlocked almost all the time, probably about 10 hours a day I wonder what kind of damage I've been doing to my poor battery?
aholbro1
08-05-2021 05:02 AM
WinterJag
16
10-09-2015 07:49 PM
