Can my car be towed?
I have a 98 xk8 that I need towed asap/tonight if at all possible.
It is parked, and it is has the following dash lights:
engine failsafe
gearbox fault
stability control
The codes cannot be read
The ecm is not in the car - believed water damage
I cannot get the car to be placed in "neutral" gear, shifter is stuck in "park"
Yes I have put the key in, turned the key, and have foot on brake.
Can I go in under the gearbox by unscrewing the "star" looking screw next to the shifter and "push" some tab in, I believe?
Any help, greatly appreciated!
Thanks!
engine failsafe
gearbox fault
stability control
Thanks!
Torx!
Since a failure is equally likely to happen on the road away from tools as it is in my garage why would Jaguar use anything but a common tool to access the release. Heck, even the tow guy might not have a TORX bit in his pocket...
Isoruku
06-19-2020 12:54 PM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
