Can someone help me understand this wiring diagram
what he said. Look at the bottom of the page you’ll see there is a section that will have that same symbol or it will be included in a range of symbols and it will point to another referenced schematic section where you will find where that wire goes
Dr. D (07-03-2023)
Dr. D (07-03-2023)
AS a general tip with the diagrams . The computer chips usually switch there loads to earth so you will find a continuous or ign switched supply on one side of the load and when you want it "ON" the earth is connected. This is the opposite to traditional vehicle wiring of the era .
Never fit non jag relays as they contain spike suppression or you can bugger the switching transistor in the computer module
michaelh (07-04-2023)
I didnt know that. I’ve opened Up some of the relays in my house six STR and I didn’t see any capacitors or mother type of suppression components other than a resistor across the coil. Also the relays that are in my 06 are a Ford brand. Where did you hear that there is space suppression on the relays?
michaelh (07-05-2023)
Bluefish001
37
07-04-2023 05:39 AM
