Can someone help troubleshoot if this is a clogged radiator or faulty Thermostat?
Old 02-02-2015, 09:28 AM
wolfpck1's Avatar
did the same here wheelmang when you have a nice sunny day to work on get the aluminum replacement for the stat assembly can crack the old one off which makes getting to the old bolts easier then replace the rear bolts with either hex bolts or ones cut with a screw slot on top also.... (make it your self with a hacksaw or dremel tool ) makes getting those rear bolts alot easier to get out if necessary in the future .
Old 02-08-2015, 12:30 PM
davejdoyle's Avatar
So, I finally replaced the thermostat and hose, but the car's heater still has the same problem. It worked fine for the first 10 minutes after the car warmed up and blew hot air for about 10 minutes, and then the hot air stopped, and would only blow cold air. Any ideas what to check next?
And Yes, my first thought is that there's an air bubble stuck somewhere in the system. I've been squeezing and pumping the hoses trying to get any possible air bubbles out, but anyone got any better ideas, if that is what my problem is?
Old 02-08-2015, 01:02 PM
Jon89's Avatar
Received 4,357 Likes on 2,849 Posts
Keep in mind that it usually takes several days to work all of the ingested air out of the system. Just keep checking the coolant level in the expansion tank and top up as necessary. When I replaced the plastic coolant outlet duct assembly in my wife's 2006 XK8 in late November, I had to add a bit of coolant on three successive mornings. By the fourth morning the coolant level finally stabilized where it belongs and has not changed since....
davejdoyle (02-08-2015)
Old 02-08-2015, 02:59 PM
davejdoyle's Avatar
I overestimated the ability of these cars in the snow...My new thermostat test drive turned into a family event with everyone pushing it back into the garage!
Attached Thumbnails Can someone help troubleshoot if this is a clogged radiator or faulty Thermostat?-img_2584.jpg
Old 02-08-2015, 03:21 PM
Jon89's Avatar
Yep, when the snow flies both of our Jaguars stay safely at home. That's what my 1999 Dodge Ram pickup is for....
Old 02-08-2015, 04:27 PM
davejdoyle's Avatar
Now I think its gotten more serious. I think I've got a leaking head gasket or something like that?
My latest symptoms;
1.) On my last test drive, the engine appeared to overheat right as I got home, and there was lots of either smoke or steam coming from under the hood. The engine temp gauge read normal, but from what you all have told me in this very thread earlier, that the gauge doesn't function like a normal temp gauge. It didn't smell purely like the sweet radiator cooking on the engine smell, just smelt like a wicked hot engine. There was possibly with some coolant smell, along with whatever else, because it wasn't a white colored steam, it was kind of a darker shade of steam/smoke, if that makes any sense. I shut the engine off when I first saw it, and it stopped shortly after. It cooled down, I added coolant, and drove it into the garage without any further issues.
2.) The air bubbles in the coolant don't seem to stop coming, its a constant flow of bubbles now matter how long the engine runs.
3.) When I have the cap on and the system is closed up like normal, the pressure in the hoses seems to be unreasonably high. Like, they're under such high pressure, I'm surprised they all don't pop off and explode.
4.) The heater still only works for the first 10 minutes, then it only blows cold air.
5.) After I replaced the thermostat, both the upper and lower coolant hoses are now hot, where as before, only the upper hose was hot, so thats my only good news.
Whats the verdict, Blown head gasket?
Old 02-08-2015, 04:29 PM
davejdoyle's Avatar
Forgot to mention, The oil is still normal looking(at the moment), meaning I can't see any coolant on the dip stick, and the coolant color looks normal also.
  #28
Old 02-08-2015, 04:42 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Yup!
There is a test kit to detect combustion gasses in the coolant as a final conformation.
Old 02-08-2015, 05:43 PM
davejdoyle's Avatar
How big of an ordeal is fixing a blown head gasket on these cars for a real mechanic? I'm pretty sure I don't want to try doing it myself.
  #30
Old 05-05-2016, 09:11 PM
cyber3d's Avatar
Bump this old thread.
Just put in the alum water pump, alum thermostat housing, and new thermostat.
Not sure if the thermostat is working however. Running at idle for about 10 minutes now and the top heater hose is pretty tight - starting to bulge. The temp according to Torque App is 188.6 degrees F. The bottom hose is tight but not bulging. Both the top and bottom hoses are hot. They relax after cooling down.
Does this indicate my thermostat is stuck?
  #31
Old 05-06-2016, 02:16 AM
test point's Avatar
Your TORQUE temperature reading is just where it is supposed to be. You rebuilt most of the coolant system on a 15 year old car without replacing the hoses?
cyber3d (05-06-2016)
  #32
Old 05-06-2016, 02:22 AM
cyber3d's Avatar
Waiting on the hoses to arrive. Transmission and all tensioners and chains were done too. So, I wanted to test the engine now rather than wait for the hoses to come. Thanks for the reply.
  #33
Old 05-06-2016, 11:54 AM
GordoCatCar's Avatar
Check the radiator by removing the radiator hoses at both entry points: top and bottom. See if you can get a clear stream of water to run in and out if these hoses with a garden hose. If yes, then your radiator is most likely not the cause. Obviously while you are doing this, change the top hose [er balloon]. I'd change both.
hoodun
02-20-2023 05:52 AM
mikiep
12-20-2019 07:37 PM
10 XF Premium
10-02-2015 09:22 PM
Lubrication
10-01-2015 03:56 AM
millertic
09-30-2015 08:11 PM
Quick Reply: Can someone help troubleshoot if this is a clogged radiator or faulty Thermostat?
