Cancelation cassette and indicator switch
Probably a daft question but...
I am getting an airbag warning light with the flashcode suggesting that the problem is at the clockspring/cancellation cassette. For some time (since I bought the car) when turning right the indicator doesn't self cancel. If I have to change the cancelation cassette is this likely to also fix the indicator cancelation issue or do I need to replace the indicator switch as well (seeing as I will be in there anyway).
tberry6686 (08-30-2015)
Managed to get a new clockspring on ebay (£140.00) and this has cured the airbag problem but sadly the indicator cancellation still does not work when turning right so I suspect the indicator switch itself has an issue.
Looking on Ebay for a replacement (cause the new price is just silly - £263 +delivery) I came across this.
INDICATOR STALK / STEERING COLUMN SWITCH - Jaguar XJ8 XJR X308 (also XK8 / XKR) | eBay
The part looks like the one in my XK8 but jaguar have different part numbers for the XK8 and XJ8. Can anyone confirm if they are the same part ?
