cant get hood open
2003 xkr, pop the latch and i hear a click but hood does not move. if i try and manually lift on the drivers side, its dead solid, if i manually lift on the passengers side the hood lifts up slightly (appears to unlatch). Since the hood dips down under the hood there is no way to get a screwdriver or even a thin spatula under there to try and move the latch. I heard the only thing to do is remove the wheel and the inner fender guard, plastic piece, and then there is a hole whereby someone can go up there with a screwdriver and unlatch it??? ANYONE ever done this or give me more pointers?? This the way to go??
Johnken
09-15-2015 05:46 PM
